- MountainAir05Explorer IIHe stated that the turn table is working so he has power to the unit. Sounds like frequency and voltage issue or ground from the gen to switch.
- You need to get a Voltage reading on Genset. From your description, the Genset voltage may be too low. Just enough to power the turntable and panel, nut not enough to power the heating supply. Doug
- mfox20ExplorerMaybe one of the breakers on the genny tripped. Most have 2 breaker switches on the side of the generator.
- rgatijnet1Explorer IIIHave you checked the circuit breakers on the generator itself? These will be right near the generator start switch on the lower portion of the generator.
- 2oldmanExplorer IIWill it run other things?
38,769 PostsLatest Activity: Apr 03, 2026
