Sam_Spade
Sep 22, 2018Explorer
DownTheAvenue wrote:Sam Spade wrote:
When I had my C, the generator would change it's sound a lot when the microwave was run while the A/C was on. Even more if the batteries were low and the converter was going full blast.
Of course it did, the higher the electric load, the harder the generator has to work. Perfectly normal and totally expected.
OK, let me re-phrase:
A microwave is a significant load. With the A/C and converter/charger running full blast AND the microwave, you might be very close to the design limits of the electrical wiring.......and you should not blindly ASSume that you can put in a bigger one without causing a problem.
38,769 PostsLatest Activity: Apr 24, 2002
