Mr_Mark1
Oct 04, 2015Explorer
Silvercorvette, you didn't say what your price range would be but one thing that I wanted to point out is that a Prevost coach might fill most of your desires.
Liberty combines the black and grey tanks with one tank adding a grey water bypass. If allowed, I can open the grey water bypass and the water will exit under the coach or I can attach a hose and run it where ever I need to put it. Our holding tank is 189 gallons. Fresh water is also 189 gallons.
We have a 235 gallon fuel tank. At 54,000 lbs., we average about 6.5 mpg.
10 yr. old Prevost still look new in many cases. They have a safe and robust chassis with real front and rear bumpers. They have no steps that pop-out as all the steps are on the inside. There are no screen doors or door awnings (a compromise of a Prevost).
2005's or so would list for about 499K-599K. Check out Prevostcommunity.com in their 'sale' section to get an idea of price, years and amenities. Slides came out in early 2000 or so. These coaches offer a 20,000 lb. towing capacity.
Good luck on your search.
MM.
MM.
