Ivylog
Oct 05, 2015Explorer III
silvercorvette, you need to slow down... use what you have to go to AZ and M Beach. If you try and pull this off in 15 days you will loose a bunch of money (which you do not have) and make a even bigger mistake on what you rush into buying.
There is no need for 200 gallons of fuel (100+ yes) and if you cannot live without that much (not likely) a 100+ gallon tank could be put in a basement bay on a DP with a tag axle (you'll need a tag for the extra weight).
