Hydrowilly
Oct 28, 2019Explorer
DrewE wrote:. You are correct DrewE. The GAWR is only 9450. I grabbed the wrong one when I was typing. Thanks for your help. That took a load off my mind that I’m good to go on towing my car.
With a tow dolly, the tongue weight (which, as DaButcher observes, is the "Max Vertical Hitch Load") is quite low. It sounds like you'll be good to go.
Incidentally, I believe you have a typo in your rear axle GAWR in the post; it looks suspiciously like the GVWR. I think it's actually 9600 pounds; but that doesn't change anything for being able to tow your Fit with this setup and equipment.
38,778 PostsLatest Activity: Jun 10, 2026
