choudrantpd's avatar
choudrantpd
Mirada Select Steering
I have a 2017 Mirada Select 37TB with app. 8,000 miles. It seems to drift as if the steering has slack when driving. It also has the Safety Plus steering stabilizer installed. The recommended tire pressure on the 22.5 tires is 110 psi and I usually run around 100 psi. I was curious if any others with a gasoline motorhome on the Ford F-53 chassis has this problem. I am contemplating taking it in to check the steering and alignment. If it is just an inherent characteristic of the Ford chassis, I will save my time and money rather than taking it to have the steering checked.
Thanks for any input or information
