choudrantpd's avatar
choudrantpd
Mirada Select Steering
I have a 2017 Mirada Select 37TB with app. 8,000 miles. It seems to drift as if the steering has slack when driving. It also has the Safety Plus steering stabilizer installed. The recommended tire pressure on the 22.5 tires is 110 psi and I usually run around 100 psi. I was curious if any others with a gasoline motorhome on the Ford F-53 chassis has this problem. I am contemplating taking it in to check the steering and alignment. If it is just an inherent characteristic of the Ford chassis, I will save my time and money rather than taking it to have the steering checked.
Thanks for any input or information
  • The most prominent reason for what you're feeling in the steering wheel is improper toe-in setting.
    The toe-in can be set with a tape measure and 2 straight pins. Never had a tape measure get out of calibration, GRIN. About 3/16" toe-in is correct.
    If you are interested in doing this yourself, let me know and I'll explain further.
    The CHF costs nothing for the rear axle but the front axle should have longer links added when doing the CHF.
    Do the above mentioned items before throwing $$ at the issue.
    Richard
  • A few thoughts; there is no alignment done once the MH is built and the recommended pressure is often wrong. The best way to know what PSI you should be running is to weigh your rig as loaded for travel (either 4 corners or at least axle weights) and adjust PSI based on the tire manufacturer's guide.
    I did all that and my gassers still rode like I was trying to steer a greased elephant on a muddy hill. The best remedy for this that I found was doing the CHF.
