time2roll
Sep 19, 2015Nomad
The house and chassis are basically separated so it is not an issue.
The alternator will charge all just fine running down the road.
But then again you could go all in with six AGM.
Bigger concern will be the converter that charges the house and the 9200 should be fine. If the 9200 is less than 60 amps I would upgrade the wire as needed and swap in an 9280 for 80 amps charging.
38,779 PostsLatest Activity: Jun 16, 2026
