Yosemitebobr
May 23, 2016Explorer
missnmountains wrote:
I agree, it does not answer my underlying question of whether or not I can mix AGM with Sealed Acid Batteries. I was responding to whether there was a switch on the charger. It appears to be automatic. As I indicated earlier, I will need to check with Jayco to determine if the house charger charges the chassis batteries. Unless someone on this forum knows the answer.
Thanks
Ken
Ken, if your MH has a BIRD (Bi-Directional Isolator Relay Delay) then yes, your charger is charging all batteries in your MH, including chassis. Check to make sure, if you have this, you need to keep all batteries the same.
38,778 PostsLatest Activity: Jun 10, 2026
