full_mosey
May 23, 2016Explorer
The answer is NO, you don't want to mix FLA with AGM.
Here is what has not been mentioned so far.
AGMs rest at 13V and FLAs rest at 12.65. If you leave them connected in parallel, the AGM will sacrifice Amps to keep the FLAs at 12.65. After some time, the Volts of the AGM will balance out to 12.65. At that point the AGM will be around 65% charged.
What is the correct charge Voltage?
What is the correct float Voltage?
I got my first AGM in 2009 and within one year went 100% AGM.
HTH;
John
HTH;
John
38,778 PostsLatest Activity: Jun 10, 2026
