- MobileBassetExplorerI can see why you would want all house batteries to be the same ( and all new at the same time) but if the engine is charging from a different source why does it matter if it (they) are a different type than the house?
- The house and chassis are basically separated so it is not an issue.
The alternator will charge all just fine running down the road.
But then again you could go all in with six AGM.
Bigger concern will be the converter that charges the house and the 9200 should be fine. If the 9200 is less than 60 amps I would upgrade the wire as needed and swap in an 9280 for 80 amps charging. - missnmountainsExplorer
bob_nestor wrote:
I wouldn't mix them but that's based on the little knowledge I picked up when I installed AGM batteries in my previous RV. The inverter/converter in it had different settings for the various types of batteries and I had to change its settings to match the Lifeline AGMs. I also bought an intelligent battery charger at the time and it has different settings for different types of batteries. That might be just marketing hype, but then again ... What little I could find in the manual seemed to indicate the optimal voltage levels used for charging were different for AGMs vs regular batteries.
This is my underlying concern. I have a very large boat with 6 8D batteries. They are all deep cycle AGM. There are three chargers. All three chargers have three settings (Flooded, Gel, and AGM) They are all set to AGM. I was told I could damage the batteries if the chargers are not on the correct setting.
My house charger in the Motorhome does not have any settings that I could find. It is the Intelipower 9200 PD 9200 Series.
Thanks
Ken - missnmountainsExplorer
2oldman wrote:
jars= batteries.
I'm not sure if your house and engine are connected.
Only to the charging systems. We have a house charger and obviously the Alternator.
Ken - bob_nestorExplorer IIII wouldn't mix them but that's based on the little knowledge I picked up when I installed AGM batteries in my previous RV. The inverter/converter in it had different settings for the various types of batteries and I had to change its settings to match the Lifeline AGMs. I also bought an intelligent battery charger at the time and it has different settings for different types of batteries. That might be just marketing hype, but then again ... What little I could find in the manual seemed to indicate the optimal voltage levels used for charging were different for AGMs vs regular batteries.
- 2oldmanExplorer IIjars= batteries.
I'm not sure if your house and engine are connected. - missnmountainsExplorer
pianotuna wrote:
Hi,
All batteries would be best to be the same. I would prefer 12 volt jars. AGM deep cycle still has a 50% limitation for depth of discharge. They do work well as starter batteries because of their low internal resistance.
If you don't camp below -20 c (-4 f) and have deep pockets consider using LI batteries for the house and for the starter. They can be taken safely down to just 20% state of charge, and they do not have to be recharged to 100% unlike lead acid chemistries.
Lifeline does a great AGM.
I just switched to used telecom batteries and am happy with the results.
Do add some solar if you boondock. If you don't--then you don't need to have four house batteries.
Thank you so much for the response. Sorry for my ignorance, but what are "12 volt jars"?
I like the idea of using deep cycle AGM's if they work as starting batteries too.
That is a great idea.
Ken - pianotunaNomad IIIHi,
38,766 PostsLatest Activity: Jan 10, 2026
