As said, it should be a very simple swap out. However if for some reason you are not comfortable with the dealer I would move on. If you special order one exactly like you want from the dealer you trust you will have it by May. You should also be able to get a better price on an ordered coach since the dealership is not doing to have to carry any interest on it. You could more then likely get 30% off window sticker price. A new coach is a lot of money so you need to be sure that it is exactly the coach that you want. Good luck.
