- David0725Explorer IIYes it is a Cummins engine 8.3 the weird thing is it was running and I went to put it in gear but the shift pad wasn't lit.
- gemertExplorerIf the transmission pad doesn't light up the engine won't start. There is a fuse for the panel, not sure what it does exactly, but others have had the problem and found the fuse bad. When they replaced the fuse the problem went away. Others have said the fuse is under the transmission pad. I'm not an expert but it seems easy to check. Good luck.
- sdianel_-acct_cExplorerCummins in Ocala:
352-861-1122 - sdianel_-acct_cExploreryou might call Cummins in Ocala. We're there now getting our radiator repaired. They might have mobile service or recommend someone. Do you have a Cummins engine?
- darsbenExplorer IIrvservicereviews.com
http://rvservicereviews.com/StateList.asp?Submit=&sortby=location&state=FL&search=&CategoryID=&ZipCode=&Miles=&SearchState=&KeywordState=
38,778 PostsLatest Activity: Jun 06, 2026
