TominTampa's avatar
TominTampa
Monaco Dynasty Alignment Specs
Hello All,
I'm going to get our 1996 Dynasty front end alignment done in a few weeks and called my local big rig alignment shop to set up the appointment. However the foreman said they didn't have the alignment specs for my 1996 Dynasty. That's understandable I thought, so I'll call Monaco and ask them. We'll that was a waste of time, so I figured I'd turn to the forum and see if anyone out there had the specs for a 96 Dynasty, 36' on a Roadmaster RR8R chassis? - Tom
  • Well, honestly there's nothing wrong. But I just finished replacing all the trailing arm bushings, (I hope I never have to do that again) with the Atro Poly ones, all the shocks, and all the airbags. So I figured since I've been messing around with the suspension it may be a good idea to go ahead and have it aligned. - Tom
  • Ivylog's avatar
    Ivylog
    Explorer III
    Why do you think you need an alignment...Uneven tire wear, pulls one direction???
    You also need the ride height spec with I think is 9.5"... maybe Executive will chime in. With a solid front axle there is not much to check other than toe in. I set my own by measuring to the same spot on the inside of the tires... front and back of the tires. If it's 1/8th + a little I'm happy.
