Diplomat_St_Poo's avatar
Dec 24, 2014
Monaco La Palma roof issues
A friend has a 2006 Monaco La Palma and was told that the entire roof needs replacing. That it was bubbled up and cracked.
I told her I would post a pic here and see what others thought. When I looked at it, I did not see any bubbles. Looked stuck down solid. The small veins appear to be caused by the wood texture under the rubber. Not sure what type of roof it is, TPO or EPDM?
Thanka All. Hope the pictur is clear enough.
j
  • Gjac
    The roof feels a bit like rubber, but our MH roof rubber appears thicker. She bought the Monaco used so she doesn't know if someone may have coated over the original. I will ask her if she has any documentation on what type of roof it had from the factory.
    There are no visible leaks, but she had delamination on her previous coach and wants to make sure it doesn't happen to this one from an un-seen leak.
    As well, were she has the MH serviced they are saying the whole roof needs replacing.
    BTW Iwalked all over the roof and it feels solid. No soft spots, no give.
  • Gjac's avatar
    Gjac
    Explorer III
    From the picture it looks like fibers in a resin matrix(fiberglass roof). It looks like random chopped fibers with no get coat sprayed down first or the gel coat is worn away from weather. I would look at the owners manual or call Monaco and verify what roof came with the MH. Secondly you could take a ball point pen and impress it into the roof if the roof is hard and the point does not sink in it is some type of FG roof with polyester resin. If it is soft it is rubber. Either way I would not replace it if it is firmly bonded and there is not cracks for water to get in.
