My_Roadtrek
Jan 10, 2014Explorer II
The carb can't be rebuilt, and you have to drop the gen-set to replace it.
Some members have had some success with running Sea Foam through it, It's worth a try, but I wouldn't get my hopes up to high.
Here is a post by Handbasket from a few years ago. He's still on the forum so you can PM him if you have questions.
On edit, just getting the fuel filter off is a real pita!
Posted: 01/05/04 03:25pm Link | Edit | Print | 13209874 | IP
For those without the time or inclination to read my ramblings, let me just say, "Believe the Onan manual! Run your genset every month! It's a b!t$h to get to on a B van, at least a Roadtrek, and is likely to cost major money if you let the gas sit in the carb." If you haven't looked, it sits in a box under the floor, only accessable thru an access plate about 8" x 15" that is wholly inadequate to work thru. Let my tale of misery be a warning! That's all.
(Warning!! The rest is long and boring!)
OK, so when I bought my new-to-me '02 Roadtrek back in the early Fall, I screwed up. The gas tank was almost empty, so we couldn't run the genset. "No problem," thinks I (bad case of wanna new van fever), "Onans 2.8's are pretty reliable, and this thing is close enough to new that I'm sure it just needs gas. It'll be OK...."
Yeah, right. 8,500 miles on the clock, 1 1/2 years old, 29.5 hours on the genset. I really didn't think about how long it had been sitting idle on the consignment lot, or with the PO, with no exercise.
Well, it wouldn't start. Cranked OK, but no fire. So I got under and took of the access plate. Still couldn't start it using the button underneath, until I figured out the choke linkage and diddled it by hand every time I wanted to start it. Then it loped like crazy, with the revs hunting up and down, up and down, cycling about every three seconds. Putting _any_ electrical load on it killed it immediately. I tried a can of fuel system cleaner, with little result.
We finally had some warm weather over the weekend, so I tackled it (don't think Onan would honor the warranty for neglect). Adjusted the choke first (this is why this is in the B van forum, instead of the tech issues forum).... dam', that's a poor design!!! You go thru the access plate at the back, and have to hold the 7 mm wrench in your bleedin' fingertips to reach the two nuts! Don't drop the wrench; it'll go out of reach in the tray under the generator! I _had_ 3 7mm wrenches; now I have two.... Why couldn't they make the access plate full width???!!! Second try got it right, and it starts fine, but still lopes...
So, yesterday, I tackled the carburetor... again, very poor design as far as service access. Fuel filter has to come off, housing is in the way of the lower hose clamp, etc.... I'm not sure you can pull the carb without dropping the whole thing out of the vehicle. It doesn't look like it. I settled for taking the float bowl off and spraying some carb cleaner in there, and filling the fuel filter with gas treatment.
Still lopes, but not as badly; occasionly smooths out entirely for a inute or two. Definitely some varnish in the carb from sitting. But now starts, runs, and even accepts a load sometimes. Making progress. Even ran the heat pump briefly.
So today, I dosed the gas tank with two varieties of cleaner (Techron and Sea Foam) and drove around to mix it up. I then ran the genset long enough to get it thru the system. I plan to start and run it every day for while to keep fresh cleaner in the carb, hoping to dissolve the last of the varnish that way. I'd really rather not drop the genset box....
Dunno if it'll work. But I want anyone who read this far to remember to exercise your generator!!!
38,777 PostsLatest Activity: May 24, 2026
