time2roll
Nov 09, 2017Nomad
What is the battery voltage? Charging may not start unless you are above 10.5 volts. Can you run the chassis engine to let the alternator bring the voltage up a bit? Once at 11 volts fire up the generator.
May need to go camping and plug it in and sort things out.
You do turn the inverter off for storage right? Even with inverter off and switches off you may have a draw on the house battery.
38,782 PostsLatest Activity: Sep 10, 2026
