Goldencrazy
Nov 10, 2017Explorer
Well the winner is no connection. Not bad, none. There is a switch between the batteries and the inverter and it was turned off. Not possible by accident so intentional. Three weeks ago i had the coach winterized at camping world. I posted as ihad a check valve problem in the water heater. I also had the generator serviced while i was there. I guess for some reason they turned off the switch and failed to turn it back on. No surprise as they failed to close the door on th refrigerator ater drain or put the cap on the tank drain. No problem as the valve was closed but should have been done. So my techs at the place where i store the coach found the problem and everything else checks out. It did reveal how little i know about the lectronics and i know alot more from reading and all your efforts to figure this out with me. Thanks for your patience. Today all is well and we should be able to leave on Dec 1 as planned. No more Camping World. I have tried but just too many things done poorly. Nice people and i so wanted to have a good RV alternative but things seem to get worse instead of better even though they are a Winnebago dealer and i purchased the coach there. Thanks again for all your patience, kindness and effort.
38,782 PostsLatest Activity: Sep 10, 2026
