Sam_Spade
Nov 10, 2017Explorer
Goldencrazy wrote:
Three weeks ago i had the coach winterized at camping world. I posted as ihad a check valve problem in the water heater. I also had the generator serviced while i was there. I guess for some reason they turned off the switch and failed to turn it back on.
What we have here is a failure to communicate.
Turning that switch OFF should be a part of proper "winterizing"; indeed, it should be done anytime the unit will be unused for more than 24 hours probably.
I'm no big fan of CW either but I don't think they deserve the blame in this case.
AND......none of that has any bearing on why your battery voltage is so low. THAT might be a real problem that needs attention.
38,782 PostsLatest Activity: Sep 10, 2026
