-Gramps-'s avatar
-Gramps-
More Tips and Hints
More Coach Tips and Hints
December 14, 2015
1. I leave a baseball cap on the dash whenever I am driving the coach. I don’t wear it all the time but it sure comes in handy when the sun is low and shines thru the gap in our double automatic windshield shades
2. While we are on the subject of windshields. I replaced my stock Monaco wiper arms with ones with standard sized J-Hooks. I purchased them from Diesel Equipment Corp in Greensboro NC. Now I can use any length frameless replacement blade, easily purchased from an auto parts store or Wal-Mart.
3. Rescue Tape works as advertised. I carry three rolls of it, Red, Orange and Clear. It can fix a hose, a broken patio umbrella and there are lots of useful reasons to have a roll in a drawer.
Capillary action (sometimes capillarity, capillary motion, or wicking) is the ability of a liquid to flow in narrow spaces without the assistance of, and in opposition to, external forces like gravity.
Do you read that? Water can go against gravity, flow UP, if the conditions are there. So here is hint number four…it’s a bit long but I suggest you read it.
4. If you have a Monaco or Holiday Rambler coach with the rubber black gutters at the bottom of the side of each of your slideouts then you need to take a close look at the bottom of the floor of each slideout, especially the main one. That piece of rubber was installed to catch the water running down the side and not let it run under the slideout where it gets wicked up by the plywood floor. There is an exposed wooden edge underneath the main slideout that is well, too exposed. The rubber gutter helps to prevent a leak problem but it doesn’t quite do the trick. The gutter funnels a lot of water to the front bottom corner of the slideout causing the floor to delaminate and then it starts to soak up water and it swells and the cycle just gets worse until one day mushrooms are growing out the bottom of your slideout. Not good. I discovered this was happening to my coach. I had a lot of rotten wood which I blew out with an air compressor and then filled the void with spray in stop gap foam in a can. Then I glued a piece of rubber sweep over the edge of the slideout so the water could not defy gravity and run underneath any longer.
If you discover you have this problem you can limit the exposed edge of the floor by running a line of deck screws through the bottom of the floor until they are flush! Don't leave any exposed screw head or it will get caught when the slide goes in and cause a lot of grief.
5. That as seen on TV stuff called Flex Seal really works. A can of white or clear or both should be a must have for your RV emergency repair kit. It is great for sealing seams on slideout toppers and quick fixing a roof leak.
6. Learn where your ice maker shut of valve is located. You don’t want to be caught by surprise and have to turn off the campground water to your coach because you can’t figure out how to turn off the water to the icemaker…not to mention the damage a leak can do to your fridge electronics.
7. After you learn where your shutoff valve is, I suggest you replace the standard plastic tubing water supply line to your ice maker solenoid with a reinforced ice maker hose. Why risk a leak from a broken water line caused by the fact it moves when the coach moves? This part is available at Lowe’s for around 15 bucks depending on the length. I bought a six foot one. It took about twenty minutes to connect it. The line from the solenoid to the ice maker (the metallic blue in the picture) is not as critical. It is not under constant pressure.
8. If your fridge was part of the recall and you now have the heat sensor relay box installed I have a hint for you. Those boxes are known for tripping and not resetting. When that happens your fridge will not turn on unless you bypass the relay. I learned a trick...you can reset the relay with a magnet. Just rub it on the back of the box until you hear a click.
9. I have a rechargeable flashlight/night light plugged into a bathroom socket. Its in the middle of the coach and comes in handy during an emergency, like the dog needs to go out in the middle of the night and I don’t want to turn on the lights in the coach.
10. I carry a CharGriller table top grill. It is a small kettle grill with cast iron grates. Best portable charcoal grill you can get. It fits in the basement but large enough to cook a mean six pound beer can chicken. This grill is available on line or at Lowe’s for around sixty nine dollars.
11. Do you have a dog that likes to spend a lot of time on the dash? Diane and I made a custom fit dash mat. We purchased comfort rugs…those things that usually go in a kitchen or laundry room and are designed to be easy on the feet. They are made out of the same thing that mouse pads are made from…urethane rubber. We trimmed the rugs to fit around the instrument panel and it looks really good on the dash. The rubber clings to the dash so it is not necessary to attach the two mats together. Our new dash mat is really easy to clean. I used the left over scrap material to make some matching coasters and a mouse pad for the coach.
Well, that is all the hints I can think of at the moment. I suspect that some more will pop into my brain and I will add to this list if that happens.
Derrick
  • holstein13 wrote:
    Where's hint #5?
    Well, I forgot that one, but now it is there.
  • PRodacy wrote:
    Seems like having a dog on the dash is really foolish. That could really impede your visibility, could jump onto you causing loss of control, do lots of other things that could cause a wreck and possibly kill someone.
    Did you really read that to mean the dogs are on the dash while they are traveling. I assumed it was while were camping.
    Nice tips, Derrick.
    Thanks.
    Tom
  • Love that dashboard idea. My new spaniel puppy thought that dashboard was built especially for him. BTW, he was in a crate while vehicle in motion.
    The other ideas were also great, having previously owned a Monaco.
    I agree with you so we don't allow the dog on the dash while the coach is in motion. He knows better and doesn't get up there.
  • Seems like having a dog on the dash is really foolish. That could really impede your visibility, could jump onto you causing loss of control, do lots of other things that could cause a wreck and possibly kill someone.
