craig7h
Sep 01, 2021Nomad II
I had a Thor ACE 29.3 for a season and a half. Traded as we found out it did not have enough storage for extended trips.
Heres my thoughts, yes the ACE is rated as a starter MH. With that being said all of the components i.e. frig, stove, plumbing are the same in it as in all other MH. Its the workman ship that leave alot to be desired.
These are my neg. comments about the ACE. The black tank was only 29gal and the bath sink drained into it. This caused the tank to need emptying very often. It also was plumbed that a 90 angle was at the bottom of toilet so everything had to turn right away. This caused a poop mountain at the base of the toilet.
I always had a problem with the water supply getting to the bath side of the camper. My kitchen was on the long slide as was the water inlet. For some reason the water line to the bath would kink, never did solve the problem.
Dollars for dollars the ACE was a good unit, drove nice enough power to deal with mountains. Things I would look at, storage inside cause not much outside. The large room slide can become problems make sure it works and learn about how to work it. Its important to keep the motors insink.
Good Luck safe travels
38,782 PostsLatest Activity: Sep 02, 2026
