Dale_Traveling
Mar 21, 2016Explorer II
I also own a 06 Hurricane but a 31D model. Problem is the chassis battery disconnect solenoid in the Battery Control Center. It's located on the engine fire wall above the engine oil fill.
To replace you'll need to disassemble the unit a bit since the solenoids are located behind the control board.
Had mine fail in the driveway. Went to start the coach and nothing. No gauges, no clicks, no runs, hits or errors. Took about an hour. Don't recall exactly which one of the three is chassis disconnect.
38,782 PostsLatest Activity: Nov 09, 2020
