Dale_Traveling
Apr 26, 2016Explorer II
bobbi.collum wrote:
I got new solenoids and I took pics. But there's two wires that are not in my pic I believe they go somewhere in the top right hand corner of the green fuse board but not sure where. One is a blue wire with a small circuler end on it and the other is a green wire with a blue end that plugs into the board some place. Anyone know or have a pic so I can get this thing back together?
I'll check my coach this evening after work but I would be really surprised if they match. Did you get the one cable that is bolted to the board? Was wondering if that might be the blue wire. You could also try powering everything up and start checking for what isn't working. Steps, dash radio LP detector and such.
Also give Thor a call today with your coach VIN in hand. They might have the wiring diagram for the BCC on file and can send it to you. I got a PDF copy of the 120VAC wiring they sent to a forum friend with the same coach as mine that Thor gave him.
38,782 PostsLatest Activity: Nov 09, 2020
