- AllegroDNomadI would do what the mfgr calls for in oil weight.
- SCVJeffExplorer
10forty2 wrote:
X3
Another vote for Mobile 1 Syn, 5W-30.
My explorer started with 0W20 from the factory, but has graduated to 5 or 10W30 Mobil-1 in its older age. It's way happier.
All of our Triton engines in ENG news vans are running 10W30 Mobil-1, and are Class C weight in city traffic 15+ hrs/day.
There will surely be those coming along to start the Dino argument... ignore 'em. Use what YOU like. - K_CharlesExplorerI use NAPA 5W20 or 30 just like the book says. I change it every 6 or 8000 miles. It has 180,000 and only uses about 1/2 qt between oil changes so I never add any.
- BillMFlExplorerMy 2012 MH Ford owners manual call for 5w20 except for extreme cold winters then its says get back to Florida. Motorcraft blended 5w20 in 5qt jug is a bargain at Wallyworld. New engines these days have much closer tolerances and don't need thick oil.
- aslaksonExplorerAmsoil 5w-20 long-life, good for 25,000 miles. Also Amsoil long-life filter. I carry a case of oil, top it off as necessary (a quar every 1500 miles or so), and get a complete oil and filter change at about a year, which is usually only about 6,000 miles. Being lazy, I figure anything that prolongs the interval is good . . .
al - dodge_guyExplorer IIWhat year is your MH? I run 5W20 in the winter and 5W30 in the summer. I tried 5W20 in the summer once towing my TT. When I went to start it the next day it clattered for about 2 seconds until the oil pressure built up. The 5W20 gets so thin when it's hot it's like water. The oil will all drain down because it's so thin! I never have that problem with 5W30.
I'de run 5W30 with how hard the engine has to work. - rvtenExplorerShould say right on the fill cap. Mine does.. Calls for 5w20. I run it year round.
I use the blend. Same thing that came in it. - TrackrigExplorer IIDifferent weights of oil shouldn't be mixed.
Motor oil and gear lube are both oils and will mix together also...........
Bill - boogie_4wheelExplorer
Trackrig wrote:
mookie6 wrote:
Thanks LVJ58. Gonna top it off and head to coos bay, or
You shouldn't "top it off" with a different weight of oil than what's already in it. If you don't know what's in it, then change it.
Bill
And why not? It will mix right in. - TrackrigExplorer II
Bill
38,766 PostsLatest Activity: Jan 10, 2026
