tdgulfstream's avatar
tdgulfstream
motor power washing
I'm thinking of buying a class a beaver diesel, I lifted the bed to look at motor and it was a bit dirty, not real bad, but something I
would want to power wash to keep clean (not anal but like to keep
it looking decent), is it safe to power wash, should I be wary of
wires blowing off. Should I be more gentle than the full blast, also
I'd like to spray the shroud side of radiator aiming inside of shroud
to the outside, any concerns? its a 99 with 58,000 miles, pretty
nice condition inside and out, my first diesel, so i'm a little nervous. Thanks
  • They make engine degreasers that come in spray cans. You spray your engine then use a sprayer to rinse everything off. I haven't used any in years, especially with the newer engines that just don't seem to get 'that' grimy any more. Still, I will use a garden hose with a sprayer and spray down the metal area round the hood, the radiator, and any area I can reach with a hose and try to avoid running water over wires.
    In older engines, if you got the spark wires wet, often times one or two of the spark plugs would foul out. In today's engines ... you can't even find the spark plugs!
    I would not use a power washer on an automobile engine (car, truck, or Motorhome), but would not hesitate to spray with a garden hose, and avoid hitting wires.
    it looking decent),
    Ahem. Engines do not need to be clean for any other reason.
    Really.
    You likely will do more damage than good.
    If it is mostly dust, blow it off with compressed air and then close the hood and don't worry about it.
  • Simple Green and a wide spray. You won't need much after the gunk has broken down
  • I never power washed my engine, but if I did I would use the lowest settings possible.
  • Older wires can break with the power of the washer, plus water can penetrate electrical connections and cause lotsa problems.
    what I do is use pine oil and brushes (which not only cuts the grease but leaves a piney smell). Rinse just with your hose, at low pressure.
