MagillaGorilla
Mar 16, 2015Explorer
Motorcycle Carrier
Anyone use one of these? What brands are best? Any issues? My bikes tend to be in the 450lb to 600lb range. One had bags so I need to make sure it will fit.
MagillaGorilla wrote:If you have no toad why not an enclosed m/c trailer and it gives you a place to keep it as well as keeps it nice during the tow. You can usually find them usedExecutive wrote:
For that small gasser, that might be too much weight on the back of it...check your specs carefully before you buy the coach so you won't be disappointed....Dennis
P.S. Remove the attempt at bolding your signature or close the bold....D
Small gasser? The RV is a 36' Damon. Is that considered a "small" gasser? To me its pretty big. Yes I know there are bigger but I would not consider this one small. But its all relative. If I had a 45' DP I would think of the Damon as small.
With that said does anyone think that the 36 footer is to small to carry a bike?
the bikes I plan to use are not real big. I plan to take either a 70 BMW R50/5 or a Norton Commando or a 68 Honda CT90. None of these are very big.
