Anyone use one of these? What brands are best? Any issues? My bikes tend to be in the 450lb to 600lb range. One had bags so I need to make sure it will fit.
I installed a Hydralift carrier on my 2015 Tuscany 45 at. Works well made some brackets with 1/2 steel that bolted under the hitch using longer bolts that held hitch in place to the frame. Put the pump in rear side compartment. Simple install
