Ivylog
Jun 30, 2017Explorer III
Fire Up/Scott, how many times are you going to keep putting out this BS...100 lbs off the front axle and why did you switch to putting it in the back of your PU? 1200 lbs that far off the back is going to take 400 lbs off the front BUT more importantly...it going to put 1600 lbs on the rear axle and 04 36GD only came with a 17500 rear axle. Obviously you never weighed your rig to see how overloaded your rear axle was...or did you and that's why you went with a PU??? Yes, you got away with it but to tell someone that 1200 lbs on the back of a single rear axle DP is no big deal is downright dangerous.
I pick up 1500 lbs off the back of my DP BUT it's a tag axle and it's heavy on the front axle so this actually helps with not overloading the front axle. Click on "How I Tow" above in my first post.
38,782 PostsLatest Activity: Sep 10, 2026
