The 3M restore kit will work if you follow directions and do the step by step procedure. Takes about an hour per lens. My time is worth virtually nothing per hour.
MrDoneIt65 wrote:
My headlight lenses fogged over. Got really bad to the point it was affecting the light on the highway. I tried one of those kits to remove the fog and that turned out to be a joke. So I decided to replace the headlights. Just like everything else in a motorhome they use something manufactured by someone else. I investigated and found out my Southwind has Volkswagen headlights made in Germany. They came from a 1999 to 2005 VW Golf GTI. I went to NAPA and found out that replacement units were over $400.00 a piece. I called Volkswagen and they said $316.00 a piece.
I groaned. Then I went to e-bay. The complete unit could be bought for less than $150.00 but they appeared to be for a VW that was tripped out by a young driver. Then I found a company that makes glass replacement lenses. I don't know if they make them for other applications.
I am posting this as a heads up. Before you replace the headlight for your unit at a high cost, do some investigating. You might luck out like I did. The glass lenses for my VW headlights cost less than $70.00 for the pair, including free shipping. And there was a video instruction on how to remove the old fogged plastic lenses and replace them with the glass lenses.
