dougrainer
May 16, 2019Nomad
You will have a hard time retrofitting a Monaco. Unless the Monaco came with a keyless entry, installing the actuator motor and running the wires thru a Monaco door will be almost impossible. The Trailer keyless entry's for aftermarket are made for the Standard Entry Doors on a Trailer. Motorhome entry doors, especially Monaco's are not the same design as a Travel Trailer door. Your best bet would be to find a Kwikset or Schlage keyless home type deadbolt and see if they will work on the thickness of your Monaco door. Doug
https://www.homedepot.com/p/Kwikset-Powerbolt2-Satin-Nickel-Single-Cylinder-Electronic-Deadbolt-Featuring-SmartKey-Security-907-15RCALRCSCP/205568464
38,782 PostsLatest Activity: Sep 10, 2026
