way2roll
May 16, 2019Trailblazer
dougrainer wrote:
You will have a hard time retrofitting a Monaco. Unless the Monaco came with a keyless entry, installing the actuator motor and running the wires thru a Monaco door will be almost impossible. The Trailer keyless entry's for aftermarket are made for the Standard Entry Doors on a Trailer. Motorhome entry doors, especially Monaco's are not the same design as a Travel Trailer door. Your best bet would be to find a Kwikset or Schlage keyless home type deadbolt and see if they will work on the thickness of your Monaco door. Doug
https://www.homedepot.com/p/Kwikset-Powerbolt2-Satin-Nickel-Single-Cylinder-Electronic-Deadbolt-Featuring-SmartKey-Security-907-15RCALRCSCP/205568464
I have one of these on the S&B house and I am not sure they would hold up to the rigors of MH travel. The inside has a plastic slide out cartridge for the batteries and it's a pretty loose fit. That cartridge has contact points on the main housing. Fine for a house but I have to imagine it would do a number on it travelling down the roads with bumps and motion. Never mind the bolt is much larger than that on a MH and you would have to bore out the slide hole significantly and the catch is pretty different. Could make the door pretty unsecure simply by trying to retro fit it.
To the OP, what's the reason for wanting to go to a device like this over normal keys?
38,782 PostsLatest Activity: Sep 10, 2026
