Vach's avatar
Vach
Motorhome sway
First trip out hauling our CRV. We have a Winnebago Aspect 26a on an E450 chassis. Just got it setup for hauling the CRV with a Blue Ox tow bar and Patriot braking system. Like usual, bumps and wind gusts and semis cause a little steering change. Typically this was one or two minor adjustments and then straight again. With the toad it took 5-6 minor adjustments, and really felt like the sway you get from hauling a trailer that is overloaded or tracks poorly. It's not terrible, but noticeable. Anybody notice something similar? Any ideas on the cause and how to fix? Thanks much for the help.
  • Vach wrote:
    Didn't have any sway or alignment type issues before I start hauling the toad.
    If it didn't happen before towing most likely a rear track bar will help.
  • If it feels like the steering box needs to be tightened up (which results in wandering) then it could be not enough front end caster. (Particularly if it is a Ford E350/E450)
  • Didn't have any sway or alignment type issues before I start hauling the toad.
  • Mine does not sway. Course it's a bit bigger with the engine in the rear.
    Might have the front alignment checked on your MH.
