36 ft Ford chassis V 10 1999 Damon Intruder gas Motorhome rocks and sways. Have new Michelin 19.5 x 6.75 tires inflated to 85 front and 90 back, have new heavy duty Monroe shocks, have 1 5/8" front an...
I have the same chassis as you on my 2000 HR 38ft Endeavor. I had a little lean to one side and also had some swaying issues as well. I had the rear springs reworked and it fixed both problems.
Later added new Monroe shocks and new rear sway bar bushings.
This the second older class A I have owned that needed spring work. Amazing difference in handling when they are set up right. Spent about 700.00 each on each motorhome for the work.
