othertonka
Jun 29, 2014Explorer
I hope you know that batteries usually just operate the interior lights, water pump, and supply 12 volts to run the refer control boards. The batteries do not supply power to the 110 volt AC outlets throughout the RV, you need to plug into a 30 amp 110 volt outlet normally called shore power, or run a generator if you have one. So more detail on whats not working would help us help you.
This link might help you understand how the 12 volt stuff works.
12 volt side of life
38,763 PostsLatest Activity: Jul 22, 2018
