Burwoods
Jun 29, 2014Explorer
othertonka wrote:
I hope you know that batteries usually just operate the interior lights, water pump, and supply 12 volts to run the refer control boards. The batteries do not supply power to the 110 volt AC outlets throughout the RV, you need to plug into a 30 amp 110 volt outlet normally called shore power, or run a generator if you have one. So more detail on whats not working would help us help you.
This link might help you understand how the 12 volt stuff works.
12 volt side of life
No lights no nothing. I believe I need Battery system to be functioning for the fridge, and hot water heater to spark on to run on Propane. We have a portable generator to plug into when needed. On board one needs to be repaired.
38,763 PostsLatest Activity: Dec 25, 2025
