Burwoods
Jun 29, 2014Explorer
enblethen wrote:
Cycle the "coach" switch. Turn it off then back on.
If this doesn't work, there should be a fuse or 12 volt DC circuit breaker that could be blown/tripped adjacent to the batteries or in the battery control panel. 12 volt circuit breakers are about an inch cube with two posts.
Many battery control panels are under the hood driver's side.
The coach switch does nothing to help. We will search for the other you have mentioned.
38,763 PostsLatest Activity: Dec 25, 2025
