invisions1's avatar
invisions1
Motorhome wont start
I have a 04 workhorse chasis with 40k miles. I went to back it out of storage yesterday and after about five minute of running it died. I was going up a steep incline and originally thought maybe all the fuel had run to front of tank. I added five additional gallons and tried to restart with no luck. I coasted back down to level ground so I know that fuel is not the problem. I have ran the injector pump with pressure valve open and getting plenty of fuel. It does try to fire when I turn it over. I pulled breather hose off and poured fuel down it with no luck. I am thinking that the crankshaft speed sensor may be bad. I have ordered one but just checking to see if anyone else has had a similar experience. thanks
  • Use to be when an engine wouldn't start it was either a fuel problem or a spark problem. Today....who knows?
  • Did you check the "IGN" fuse?
    Do you have a OBD-II code reader?
