bennefimExplorerApr 04, 2018Mounting an exterior coax connection to motorhomeI would like to install a coax cable from the BOMB to an area on the drivers side of MH allowing me to connect the portable dish without routing wires thru the slide, window or door. The problems is h...Show More
Related ContentQuick connect exterior shower hose doesn't connect.Nautilus P1 has leaking connectionsVehicle mounted vs Motorhome mounted tow barMounting residential panelsB+ motorhomes
