bennefim's avatar
bennefim
Mounting an exterior coax connection to motorhome
I would like to install a coax cable from the BOMB to an area on the drivers side of MH allowing me to connect the portable dish without routing wires thru the slide, window or door. The problems is how to hide the cable from overhead cabinet down by the windshield to under the dash. Once there I can handle the rest. The RV is a 2006 Pace Arrow. If anyone else has done this please share.
Thanks, Doug
  • Does it have a cable TV connection? Could use that to utilize the cable already in place. You can use a diplexer if you'd like to have cable and satellite connections both useable.
  • Pull the side front windshield molding on what ever side you want. Usually just a few screws. One side will already be full of electrical wires so look at the other side. You really don't want to mix them. Get some RG-11 over the RG-6 and that will help.
