azdryheat wrote:
This applies only to DirecTv; only the roof-top Travler will recieve HD signals (from the three satellites). I used a tripod mounted antenna and while it worked OK, sometimes it was a real bear to get dialed in. The Travler is mush better, push a button and forget about it. I installed the Traveler myself and it was fairly easy.
Okay, that's a biggie. I do want HD. Can the traveler be mounted on a tripod or is it intended for rooftop only? The unit they sold me is the Weingard Carryout G2 and the Q&A says no HD. I can still get the Traveler but I'll have to get the install done if it has to go on the roof. I'm not into DIY anymore.
