upsidedown Charlie wrote:
My new box shows up on my account so to the second question, yes.
I'm not sure how to change the setting you are asking about. Given that it records properly and the channels all come in perfectly, I'm guessing yes. I have combed the settings. There is one section under 'satellite" that I'm not sure about because there are some menu settings that I can see but not not get to. I put in the proper zip code. Other than that crickets.
To be clear - I believe that your answer is yes my box shows up on the second account vs just one account for all receivers???
The reason I asked about the settings is you said 2 of the 3 sats (I assume 99 and 103) have errors. Your dish manual should state what settings to use. Try 7. Menu-Settings & Help-Settings -Satellite-Repeat Satellite Setup: Dish setup:
