Ivylog
Mar 03, 2018Explorer III
If you decrease the width of your pictures to 650 it will help. IF, not likely the wood of the wall inside is thick enough a simple wall mount will work BUT you may need to add a backing plate by taking out the other TV if the wood is 1/4". Same thing down below but hopefully you can add the backing plate from the wheel well. A mount with a swinging arm for below.
