EMD360
Jun 30, 2023Explorer
Winnebago Minnie water supply pipe problem
Help! I cut the water hose to install a pressure tank next to the water pump. But I cannot get a new fitting clamped on the hose without a terrible leak. I already cut the hose and installed a winterizing valve and that accepted the new fittings!
I have attempted three new fittings, cutting about 1/2 inch off after a failed attempt. Two were screw clamps. Two different screw clamps with the same fitting and a different fitting with a cinch clamp which was almost impossible. I worked on this all afternoon and I’m defeated.
Some of the pipe is blue. I can’t tell if it’s pex or not. Does not seem flexible like pex. I have a lot of pex so I was hoping to replace the hose with pex. Does anyone know the type of blue pipe used? I can’t use sharkbites on the hose but I might be able to reach this connection and cut it to accept a sharkbite. It is extremely difficult to reach! But if it would accept a sharkbite connector I could extend from the blue pipe to the tank.
