enblethen wrote:
I looked on line at the control panel. Could not read the print on lower left switch. Looks like a 120 volt sized switch with a two word description.
Lower left....IN/OUT Front Slide
Lower right...IN/OUT Rear Slide
Above front slide switch
Water heater
ON/OFF and RESET under Fault Light (Propane Only)
Electric ON/OFF outside compartment lower left corner like ALL Suburbans with electric element.
Inside switch...ONLY if RV Mfg. provides one!!!!
Simple solution......install an additional one in series with OEM one.
120V AC wiring inside junction box in backside of WH Tank
Simple.....done!
