pnichols
Mar 06, 2018Explorer II
We have only a 24 foot Class C, so we don't need to tow for our travel, sight-seeing, and camping. What we would like to be able to do occasionally, though, is have a rental place bring a Jeep to us for off-road exploring from where we're camping with our Class C. I doubt they rent jeeps and bring them to you ... have you heard of this being available?
For what it's worth, here's a partial list of some of the stuff we always bring along in our 24 foot Class C:
- Digital thermometer inside your RV that shows the outside air temp.
- Voltmeter on the dash going to the house 12V system so that when going down the road you are SURE that both the alternator is charging the house batteries and that your refrigerator is getting the 12V it needs.
- Ammeter somewhere on the wall that shows how much current is going into, or coming out of, your house battery bank at all times.
- Reverse flush system for the grey/black tanks.
- Hookup power adapters for every conceivable campground power receptacle situation/combination.
- Black tank dumping hose extension(s) to provide at least 30 feet of reach.
- Outside 12V receptacle and a long extension cord for it so that when dry camping you can run items such as lights, fan to shoo away the flies, etc. at a picnic table.
- High pressure air compressor in case you ever have a slow tire leak and have/want to make it to the next service location. - As large a tool box as you can fit somewhere and know how to use.
- Spare quart(s) of generator oil and engine oil.
- A portable or built in inverter .... pure sine wave if you can spend the $$.
- A designated junk drawer inside your rig for everything .... repair tape, spare fuses for, spare flashlight batteries, cable ties, glasses repair screwdriver set, spare outside hose inlet protector cap, velcro strips, etc..
- A long freshwater hose to both fill your tank or use for water hookups when the faucet is a long ways away.
- An adapter for the above hose so you can hook it to a drinking fountain for water at primitive campgrounds.
- An pressure reducer for the above hose for hookups so you don't damage your RV's internal plumbing from excessive campground water pressure.
- A set of jumper cables to help other campers and serve as backup for going between your house and chassis battery(ies) in case your boost relay won't engage someday when you need it most because your chassis battery won't start your engine.
- A spare tire with the jack and tools that go with it to change a tire.
- Plenty of leveling blocks for occasional spectacular sites that might require as much as 4-5 inches of lift on each of the four(4) rear duals.
- Cover for the windshield.
- A wall clock that you can see from as many places inside as possible.
- Magazine racks velcro'ed on the wall at one or more locations inside.
- A shovel .... full size if you can figure out where/how to carry it.
- A tree branch trimmer, if possible, for those rare but spectacular camp sites that haven't received enough TLC from the maintenance crew.
- Fishing poles and a tackle box just in case.
- A complete medical kit that you buy or put together yourself.
- An electric heater for when you have hookups.
- A long coax cable for TV hookups at campgrounds that offer it.
- A portable fold up picnic table for up to four to eat at for those ocasional sites that have no table, a bad table, or when you pull into site intentionally "the wrong way" (see "Another consideration" below) thus putting the site table on the wroing side from your awning.
- At least two chairs for the above.
- One or two full blown lounge chairs so you can really kick back on those "it really doesn't get any better than this" occasions.
- Another consideration ..... all my hookups are long enough so we can pull into hookup campsites "the wrong way" where the hookup facilities are on the opposite side of where it's intended they be used. This permits better positioning at certain sites for the view, or for putting your awnings together when traveling with another RV.
38,782 PostsLatest Activity: Sep 10, 2026
