Dale_Traveling
Jul 01, 2015Explorer II
rgatijnet1 wrote:Last owner had the sat antenna install on my coach and there's about 10' of coiled wire, coax and control, up behind the TV above the dash in the front cap.
The Winegard came with two very long cables for the coax and the control so the extra is probably coiled up somewhere inside of your coach. I doubt if anyone cut the control cable since it has connectors on each end. If they did cut the coax, it would be easy to add an extension cable.
38,782 PostsLatest Activity: Aug 31, 2026
