tev123's avatar
tev123
MPG woes
I searched the class b forum for mpg related topics and found/read a bunch.
First far trip on my class-B,
1990 Ford Econoline 250 Intervec Falcon with Ford's 5.8L windsor V8
No check engine lights, passes emissions, recently replaced a few cracked hoses around throttle body and a bad throttle position sensor. No bad ECU codes either.
Did a 135 mile round trip and used up 15 gallons, thus 9 MPG!!!
90% highway at around 60mph. Light wind.
Not carrying anything externally other than what came with the van (roof top/ac) and 2 solar panels that lay pretty flat (about 1" gap between roof and panel)
Tire psi at 60 front/80 rear.
Is this normal/avg? anything substantial I can do to improve MPG?
Thanks!
  • Might try a bug deflector on the front of the hood. It may direct the air up over the top a little more efficiently.
  • a friend of mine used to have a 1991,looked exact same as yours. got 14.3 mpg averaged over 1200 mile round trip. for what its worth.
  • had 1998 looked almost like yours ,got 14teen all day long. we don,t drive over 65 mph. my 2007 LTV only gets 20mpg its a mercedes benz 5cyc diesel.
  • Other than driving slower there is not a whole lot you can do to vastly improve mpg. We tow our 32' TT and average about 8 mpg if we don't go over 65mph, unfortunately we tend to go a bit faster on the instates out here in the West. I stopped fretting about mpg early on when we starting RVing over a decade ago knowing it is just part of the cost to enjoy this lifestyle. Haven't recorded mpg on a trip in over ten years.
  • I had a PW, it averaged 12-14 on the highway, normally 55-60 mph. Mine did not have the high top your picture shows. Around town was about 9-10. I agree with the statement, do about 3 fillups, average the 3. Also, if you were running generator, that figures into it
  • That mpg doesn't surprise me. For the year and the rig. If your willing to travel at 50 mph you will probably gain a couple mpg.
  • Sounds bad. I get about that + or - 2 with our 30 ft. Class C V-10. But before you give up realize that the way we check MPG isn't real accurate and 1 short trip isn't enough to get close to a true reading. But, if you can't get 12 or 15, I guess why have a Class B?
