maddawg46's avatar
maddawg46
Mud flap extensions
Got a new Newmar Class A. The mud flaps are pretty short. I wanted new ones, but big rig ones are 24" wide. Mine are 20" wide. I want to add about 6 inches to mine. So total length would be 32 years nches long.
So my idea was to add to what I already have. Anybody done that? And where did you go? Did you use rubber?
  • I recently extended the behind the rear wheels mud flaps on my Class C. I needed to add 12ins. I purchases two heavy rubber universal mud flaps from a local truck accessory business. They were approximately 19 X 24 each. I cut the size I needed. I over lapped the bottom of the old flap and the new flap material about 2ins. and attached them horizontally with bolts and locking nuts through pre-drilled flat metal front and back and the two layers of flap material. The flaps are now 4ins from the ground.
