Macktee
Jan 22, 2014Explorer
paulcardoza wrote:
I chose the warm white style, instead of the multi-color. Spend a bit extra and get the brightest you can find, which is also dimmable. Then you can adjust them as the situation requires when outside....
Our coach has a Girard Awning, so I stuck them underneath the edge alonf the wall of the coach. Then I ran the power cord in behind the entry light and wired it inside the coach, behind the inverter control panel. The remote works from outside or inside, perfectly.
I can have the lights very bright for playing cards, reading, etc, and can turn them way down for "mood lighting" most other times.
X2 what Paul said and make sure they are the cool white. Much better lighting. And having the remote, that you do not have to point right at it is invaluable. These are a little more expensive and come in 39" lengths, but well worth it. Macktee
38,768 PostsLatest Activity: Nov 21, 2015
