Ivylog
Jan 22, 2014Explorer III
Not sure an electric awning is any help as mine is 120V and those with a motor in the tube only have power when the motor is running. I had to drill a small hole through the side to get power from the 12V lights inside. With a normal roll up awning I would probably mount the light strip just under the awning when it is rolled up so you can still use it with the awning in. I have to put my awning out a little bit to use mine so maybe I should have mounted the light strip on the outside bottom of the channel, not inside.
38,768 PostsLatest Activity: Nov 21, 2015
